Plamen 0
I have a Fibaro Walli Dimmer with number of dimmable LEDs, which work perfectly in another place of the house with the same type of dimmer, but for some reason the auto-calibration recognises the load as non-dimmable. Regardless of what I do, adding bypass and forcing calibration again, overwriting the auto-calibration with "ON/OFF mode disabled (dimming is possible), nothing seems to trigger dimming for them. While the auto-calibration is performed, the LEDs are dimming perfectly visually but at the end of the process the result is "load recognised as non-dimmable".
Interesting to mention that dimming did work once for them, at the very beginning (quite smooth), then I've forced auto-calibration by accident and nothing seems to get the dimming back.
I've got a 3 wire setup, with Fibaro Bypass 2, LEDs are 4 x 10W with dimmable TRIAC driver (trailing edge).
Any help is highly appreciated.
Thanks.
