PopUp Service images
I am creating a PopUpService in my scene.
One of the settings is the image URL.
I tried an image URL external to Fibaro and it didn't work.
How do I find the URL of the icon images I have within Fibaro?
5 answers to this question
Here are some links to icons on Fibaro Home Center:
ROOM: http://<YOUR_HC_IP>/fibaro/icons/rooms/*.png
SCENE: http://<YOUR_HC_IP>/fibaro/icons/scena/*.png
VD: http://<YOUR_HC_IP>/fibaro/n_vicons/*.png
Of course in above links you have to replace <YOUR_HC_IP> with IP address of your HC. Also replace * with name of the icon.
To find name of the wanted icon you can use HC REST API or just go to change icon for room, scene or VD and then right click on icon in browser and select Save Image As... to see name in Save window.
If your HC IP address is set by DHCP (not static) then you will need this code to get HC IP address just before sending popup message:
Hope this helps.
    Awesome! Thanks @Sankotronic
    Follow Up question: What if the icon is uploaded but not assigned to a Scene or Device? Can I use it in PopUpService?
    Further Question: should this be "scena" or "scene"?
    Here are some examples of what I am trying - none resulted in icon showing in PopUpService:
    'http://<IP>/fibaro/icons/scena/Elsa 128x128px.png'
    'http://<IP>/fibaro/icons/scene/Elsa 128x128px.png'
    'http://<IP>/fibaro/icons/Freeze Shutters LR/Elsa 128x128px.png'
    Hi @Lenny212 ,
    links are copy pasted and are correct. scena is correct, it is in Polish.
    Names of custom icons are usually User1020.png where 1020 is ID of the icon. That is why I give you solution how to get icon name. Another solution is to get my
    With Icon preview VD you can easily find all HC installed icons names for rooms, scenes and virtual devices :-)
    NOTE
    If you use icons that are installed locally on HC then they will be shown on mobile app only if mobile device is connected to HC on local network. They will NOT show when you are out of your home and connected to HC remotely.
    If you want to show icons on popup notifications when not at home then you either need to connect to HC using VPN or place icons on some FTP server on the internet.
    Thanks so much for the detailed follow up response @Sankotronic
    I will give it a go!
