Guest jodohl
I have set up a Nexa wallplug to switch and dim some lights. This is working well, both through my Fibaro app and my HCL.
For convenience I want to control the Nexa dimmer through a HeatIt Z-Push Button8.
I have set up the Push Button8 in my HC by using the simple setup available in the web interface. I can switch lights, but push & hold will not dim as expected.
I have in fact the same problem with Fibaro Dimmer2 in another HC2 system. Pushing the defined HeatIt button will switch, but holding will not dim.
Ideas or suggestions would be much appreciated.
