TSN1 1
Hi everybody,
Who can help me with my lil problem. Im trying to get a 0-10Vdc signal to my ventilation box controlled bij air quality.
the higher the Co2 gets the higher the 0-10Vdc signal gets.
Now i have been writing some LUA (im a beginner of the beginners). with a bit of cut and paste and modifying etc etc etc.....
but i cant get a finger on the problem in this one:
%% properties
%% globals
448 value
467 value
470 value
473 value
%% time
%% autostart
while true do
local LQ1 = fibaro:getValue(448, "value");-- ID of Air quality woonkamer
local LQ2 = fibaro:getValue(473, "value");-- ID of Air quality slaapkamer 1
local LQ3 = fibaro:getValue(467, "value");-- ID of Air quality slaapkamer 2
local LQ4 = fibaro:getValue(470, "value");-- ID of Air quality slaapkamer 3
local LQsturing = 496; -- ID of WTW sturing 0-10Vdc
Q40 ="400"
Q45 ="450"
Q50 ="500"
Q55 ="550"
Q60 ="600"
Q65 ="650"
Q70 ="700"
Q75 ="750"
Q80 ="800"
Q85 ="850"
Q90 ="900"
Q100 ="950"
if ((LQ1 > Q100 ) or (LQ2 > Q100) or (LQ3 > Q100) or (LQ4 > Q100))
then
fibaro:call(LQsturing, "setValue", "100")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 100% sturing"); end
elseif ((LQ1 > Q90) or (LQ2 > Q90) or (LQ3 > Q90) or (LQ4 > Q90))
then
fibaro:call(LQsturing, "setValue", "88")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 90% sturing"); end
elseif ((LQ1 > Q85) or (LQ2 > Q85) or (LQ3 > Q85) or (LQ4 > Q85))
then
fibaro:call(LQsturing, "setValue", "83")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 85% sturing"); end
elseif ((LQ1 > Q80) or (LQ2 > Q80) or (LQ3 > Q80) or (LQ4 > Q80))
then
fibaro:call(LQsturing, "setValue", "78")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 80% sturing"); end
elseif ((LQ1 > Q75) or (LQ2 > Q75) or (LQ3 > Q75) or (LQ4 > Q75))
then
fibaro:call(LQsturing, "setValue", "73")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 75% sturing"); end
elseif ((LQ1 > Q70) or (LQ2 > Q70) or (LQ3 > Q70) or (LQ4 > Q70))
then
fibaro:call(LQsturing, "setValue", "68")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 70% sturing"); end
elseif ((LQ1 > Q65) or (LQ2 > Q65) or (LQ3 > Q65) or (LQ4 > Q65))
then
fibaro:call(LQsturing, "setValue", "63")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 65% sturing"); end
elseif ((LQ1 > Q60) or (LQ2 > Q60) or (LQ3 > Q60) or (LQ4 > Q60))
then
fibaro:call(LQsturing, "setValue", "58")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 60% sturing"); end
elseif ((LQ1 > Q55) or (LQ2 > Q55) or (LQ3 > Q55) or (LQ4 > Q55))
then
fibaro:call(LQsturing, "setValue", "53")
if tonumber(fibaro:getValue(LQsturing, "value")) > 0 then fibaro:debug("WTW unit krijgt 55% sturing"); end
elseif ((LQ1 < Q50) or (LQ2 < Q50) or (LQ3 < Q50) or (LQ4 < Q50))
then
fibaro:call(LQsturing, "setValue", "0")
if tonumber(fibaro:getValue(LQsturing, "value")) < 5 then fibaro:debug("WTW unit krijgt 0% sturing"); end
fibaro:debug("Woonkamer is " .. LQ1 .. " ppm");
fibaro:debug("Slaapkamer 1 is " .. LQ2 .. " ppm");
fibaro:debug("Slaapkamer 2 is " .. LQ3 .. " ppm");
fibaro:debug("Slaapkamer 3 is " .. LQ4 .. " ppm");
fibaro:sleep(60*5000)
what is wrong with this???
Thanks for helping!!
Greetings TSN
6 answers to this question
