Scene activation when device is connected to zwave network
Hi!
I have an idea. Now I'm opening my gate with fibaro keyfob and I'm travelling with this device in my car.
Maybe is there any option to create a scene which will activate, when the fibaro home center will detect that key fob is in the range of the fibaro antenna?
What do you think about it ?
Or maybe can we use the fibaro binary sensor in this case ( by connecting to USB or 12V car in plug) [but not to read any values, but just to check if this device is in the range of fibaro antenna].
According to  the Zwave proto your Fibaro key-fob will trying to connect to first nearby powered zwave device and this zwave device will as repeater for your keyfob. But you can’t create scene where you you can handle this fact
Fibaro can’t provide this functionality
PS: for geeks: probably you can after key-fob command can get from master node of keyfob the “last route Node ID” and if this value not 1 it means what you far from your HC2
IMHO
Edited by 10der
