How to wakeup Aeotec Multisensor 6
pierrot10
Dear Sir or Madma,
I am new with Domotic and I traing to get the Luminosity of the MultiSensor 6 with Jeedom.
Actually my room has the light off and the sensor show me 0 Lux. I switch the light on and the sensor still show me 0 Lux after one hour.
I change the Wakeup interval to 300. It means the sensor should show a new luninosity value after 5 minute.
Morever, I chage the value of Luminance report Threshold to 5. It means after variation of 5 Lux, a report should be send to my Jeedom controller.
I can not be sure, but it look like the report is sent after 15mn instead of 5mn.
(I am aware, 5 is not a good idea for the battery life)
I would like to solve that problem, in the way that the MultiSensor 6 show a new value as soon as possible, when the luminosity changes.
For now I have no solution and my idea is the send a command from the Jeedom controller, to wakeup the sensor, and the to get a report.
I do not know whcih would be the best way to get the new value as soon as possible, or as soon the luminance (light) changes.
Would you a suggestion to get the goal? Which parameter should I change? which action should I create?
Many thank for your help and happy new year!!
Edited by pierrot10
Hello
If you are on firmware 1.13 you can have a look here.
Good Luck, and also Happy NewYear
