Hi there I have tried recovering my HC2 and as the recovery starts, it says the recovery failed due to a corrupt recovery file.
Would any one be able to help please ?
Thanks Mitch
5 answers to this question
Not sure if it helps but try to make a new backup. When finished then load the backup version you want. It is worth a try.
    Hey Thomasn, thanks for your reply.
    When I take it out of recovery mode it doesn’t load into the login menu.
    I think I need to do a manual install of the firmware in the recovery centre.
    Any other ideas ?
    Thanks Mitch
    Ok. I see. Have you tried to boot into recovery mode?
    @mitchcoates91 if you contact support they can install a new image  remote for you, i got that help just before christmas.
    Excellent thank you, ill send them a message :)
