(SOLVED) Change multiple Scene icons
Hello
I have created various scenes that work.
Now I would like to make sure that when I activate a scene, the icons of the other scenes change.
This is the portion of the code.
    fibaro:call(27, "pressButton", "2") -- Spengo Cuore
    fibaro:call(28, "pressButton", "2") -- Spengo Gatto
    fibaro:call(4, "sendDefinedPushNotification", "221") -- Invio Notifica iPhone
    api.put('/scenes/12', {iconID=1005}) -- Cambio icona scena Vedi TV   <---- THIS WORKS
    api.put('/scenes/3', {iconID=1002}) -- Cambio icona scena Fuori Casa
    api.put('/scenes/5', {iconID=1002}) -- Cambio icona scena In Casa
    api.put('/scenes/6', {iconID=1002}) -- Cambio icona scena Notte
    api.put('/scenes/8', {iconID=1002}) -- Cambio icona scena Romeo
    api.put('/scenes/4', {iconID=1002}) -- Cambio icona scena Soggiorno
    api.put('/scenes/7', {iconID=1002}) -- Cambio icona scena Porta
    fibaro:debug("Scena Vedi TV Attivata!")
When I launch the scene, however, only the first command (  api.put('/scenes/12', {iconID=1005}) ) is considered.
Where am I wrong?
Edited by MarcoTorino71
7 answers to this question
Se ben ricordo avevo provato anch'io la soluzione del cambio icona delle scene... richiede qualche istante per processare... dovresti risolvere mettendo in pausa i passaggi per un secondo o due... prova...
    fibaro:sleep(1000) -- un secondo oppure aumentare a 2 secondo
Edited by alexpelli
    I set the sleep to 2 seconds, but nothing to do...
    Small integration.
    The code is inside an IF condition.
    I did some tests and the scene exits the condition after changing the first icon.
    On 1/10/2020 at 10:18 PM, MarcoTorino71 said:
    OK. Found the solution.
       Hi and what was your solution?
    was it they delay?
    was it they delay?
    I did it this way at first:
    I modified all the icons except for the scene itself at the beginning of the passages. At the end of the code, before finishing everything, I modified the icon of the scene in use.
    Now I changed the logic instead. I created a separate scene that checks the variables, according to the variable modify the icon itself. This way it's also more streamlined the code of the various scenes and if I add a scene I have to modify only the one of the icon change.
    Thanks Marco for reply
    Yes i got it to work the same separate scene
    which changes icons depending on globals
    trick was to find scene icon ids through hc2/docs
    thanks again
