Alarm panel remove scene
After you add a new action/scene on the alarmpanel, how can you remove it from the panel?
I've tried to click the 'add action' button and then unselect the scene to be removed.
Clicked the Add-button... because it's the only option.
Then my HC freezes and I have to reset it manually.
Thx
    Hi again,
    the only option was to delete the scene from the scenes tab. Then it was removed from the alarmpanel as well.
    @fibaro is it possible to add a software solution, for instance a remove button to the panel?
    thx.
