FGWP102 Metered Wall Plug Switch Parameter 11 setup
Hello to all,
I use a FGWP102 Metered Wall Plug Switch to switch in combination with a window open contact. In addition I would like to setup a rule which sets the FGWP to off only if the momentary power is over  5W and the window is open, for example. In normal operation the power consumption is only less than 1 W. With the standard setting for Par 11 (15%) the Switch constantly reports change of power because the change from 0.3W to 0,4W is more than 15%. Naturally I can set this to 50% to avoid permant reports. But in my opinion this makes nos sense, because 50% of operating at a higher level (e.g. 200W) is nuch too much. From my point of view there should be an additional parameter to have a minimum change in physical units (not in %) which must also be true to generate a report. If % is the only way, than it should be in % of measuring range and not of momentary value. This is useless.
Any ideas how to manage this without having permantly changes reported?
Edited by berndh
writing corrections
