Fibaro Home Center 2 unresponsive activity light lit
About twice a week, the unit becomes unresponsive and the activity light is solid a few seconds after I use a device like a switch. I have to turn the device off and on again to make it work again. I have tried two firmware versions (the current 4.570 and the previous) but same problem. I have tried connecting the HC2 to a grounded outlet but that didn't help.
Here is a short video of the problem:
Link to post
13 answers to this question
Yay!!!! Yay!!!!
FIBARO PLEASE!!! It’s not an accident! Please fix it!
Link to post
This is exactly the reason i sold both my hc2.
And if a mircale happens maybe i am going to try the hc3
Link to post
Looks like nodon, hmm, try to exclude it, do factory reset on it (both bottom switches together, till it starts to blink with colors) and include it again (as z-wave device, not controller, not secured, not NWI). Once included, let it for a week or so to see is it does create same problem when no scenes nor associations has been added to it.
Link to post
What kind of switch you're using?
Usually the problem is not HC2, but the device "bombarding" Z-wave. (Wrong parameter or association configuration)
When you don't use this switch is your system runs well?
Let's try something interesting.
Download Z-wave monitor and start it. After few minutes press this switch (according to your video HC2 back to normal at least for the first time).
Now you can see on Z-wave monitor Zwave activity of this switch. See if it overloaded...
Link to post
@cag014 What switch? Where switch?! What zwave monitors?!
The topic starter said what HC2 HALTED and he use HC2 like a switch - turn OFF / ON on the back side button
Link to post
@10der
Did you see the video?
There is some remote switch that by pressing button the Z-wave LED on HC2 is ON for a few seconds and after while the unit becomes unresponsive...
"About twice a week, the unit becomes unresponsive and the activity light is solid a few seconds "
At least that what I understood.
By the way what it means to use HC2 like a switch? switch for what?
Link to post
I do not have your problem with the latest update to the Homecenter. However, I did see a similar problem with older versions. To handle that, I wrote a small lua script that restart the Homecenter every sunday. That has kept the problem away. If you want, I can show you the lua-script.
Link to post
#reboot
;) thank you. I know 3 ways how to reboot HC2. With LUA / no LUA  /with hardware ;)
Link to post
45 minutes ago, 10der said:
#reboot
I know. The message was not for you :-)
Link to post
18 minutes ago, cag014 said:
Guys, reboot doesn't solve the problem
Yes, @Bodyartstrong recommend me use sledgehammer
Link to post
"Don't force it, get a bigger hammer."  😜
Link to post
An update! (I'm darkultra, had problems with Fibaro ID things)
I have an Asus RT-AC88U router right beneath my HC2, and when I disabled the 5GHz band the HC2 has been stable for a little more than a month. Strange.
Link to post
