Soft 17
Hi all.
I'm trying to "link" this two devices, using the strip to feed the thermostat with the correct temperature.
There is no way to use the internal, or external sensors in the thermostat.
I'm looking for one easy button on in the app, to turn on and set temperature to 22 degrees C
And one button to set the temperature to 10 degrees C, when away.
All suggestions are welcome, this is HLC, device is the 60.xx range
/monthly_2020_01/image.png.b34b037c88a00221b9e5a917171aae17.png" />2 answers to this question
