Fibber 1
Hello, after replacing the battery at Fibaro KeyFob, the keychain has become angry. After the first use, switching on the scene, then any red button shines long red ice. Unlocking doesn't work either. It looks like it's not in the system. When I press a button several times, mostly a triangle, a white LED starts blinking and KeyFob can be added to the system. I did that by removing KeyFob, restarting the HC Lite, then adding, setting, everything OK. But then the same thing happened, after using KeyFob for the first time, the red LED once again illuminated for any squeezing and again it can be added to the system again. I also tried to restore the system from a backup, but it does the same. I did the removal, adding, about 10 times, the same result every time, after the first use again a longer glowing red saltpeter. I cleared the consumption meters and it didn't help either.
What with this?
This started to do after replacing the battery, there is a new, functional one. The unit is HC Lite version 4.570. It worked before replacing the KeyFob battery in this version.
Thank you for your advice.
