Migration support from Homecenter2 to Homecenter3
I suggest that the new Homecenter3 will get a function where backups from Homecenter2 can be downloaded and installed from the Fibaro Cloud and converted automatically to the new homecenter.
Pros:
1) It is what user expects from a serious company.
2) Scenes, VDs and block scenes can be reused without further programming.
3) Users of Homecenter2 will probably want to upgrade = more units sold.
Cons:
N/A
Hi @Thomasn it is not that easy how you wrote. In backups HC2 we got dump of z-wave chip and that dump It is incompatible with the HC3 chip, so we can't move the devices in this way, so we plan to add a wizard which will allow us to move devices from HC2, HCL to Hc3. Unfortunately, we won't be able to keep the device ID, (the names of the rooms or the names of the devices, associations, parameters we should succeed) Transferring other settings because HC3 has a very improved layer of low OS will not be able to transfer either
HC3 don't have Virtual Device we have replaced them with a new better element, called by us Quick Apps. Because it uses the LUA scene engine and the individual controls are operated differently, they are not backwards compatible.
The same applies to block scenes, which now look completely different, and additionally use a new syntax, so they are also not backward compatible and have to be created again on HC3.
@A.Socha That sounds great that you have at least some way to move existing devices!
I understand the current LUA code in scenes can't be automatically migrated, and not copy pasted either?
Will I be able to code the same logic in HC3 as in HC2? So creating a new scene in HC3 and the manually coding LUA to get the same result as I did in HC2?
Yes LUA scene will have other syntax we moved from fibaro:debug(string) to Fibaro.debug(tag, string), we killed fibaro:sleep so now to delay we will use fibaro.setTimeout
We completely changed trigger blocks, management of instance
Generally yes it will have the same logic but some commands and trigers may be diffrence and you will get that same what was on Hc2 or it will offer you more with better control
@A.Socha Awesome! This was good news :) Thank you for the quick response!
In Lua, how does a scene figure out what triggered it? On the HC2 it was very common to call fibaro:getSourceTrigger() to understand what triggered the scene (from triggers declared in the header) and take actions accordingly. Is there a new way to figure that out with the new scene conditions/trigger declarations?
We will release documentation. In short there will be separate section trigers where you with logic will chose
for example for button with 1 press
or when binary switch is ON
or you can mix them device 25 is ON and one of (device 26 or 27 is on)
2 minutes ago, A.Socha said:
We will release documentation. In sort there will be separate section trigers where you with logic will chose
That is an example of a single trigger condition.
The new syntax supports multiple triggers as well. I think @jgab is refering to those multiple conditien cases... If I am correct there is no "fibaro:getSourceTrigger", but I may have missed something...
Yes, I think I understand the new trigger/rule logic.
However, from my Lua code I would like to understand specifically what condition/rule triggered as we can have OR in rules/conditions.
Would be nice if the rule/conditions could set labels/vars that could be tested against in the code later on.
in action section
it working too so you can made if device 26 then show "x" when device 27 then "y"
The major change is let say for power metering before was
23 power
so every change was start scene, now you can crate condition when that scene should start on every change of value or only when power is bigger/ lower/excaly then 35W
Condition/Trigger decide when scene start, action section what you want to do
As mentioned here, no more "sleep" on HC3. Nothing new if you have been around here for a while. But if you are new you might have not noticed "setTimeout". The replacement uses a callback style, like httpClient. I wrote a small introduction a very long time ago:
20 minutes ago, A.Socha said:
in action section
23 power
So if I have a rule/condition that triggers the scene if any of sensors s1,...sn is breached, I have to loop through all the sensors in my action section to see what sensor triggered last, to get what specific sensor triggered the scene. This can get very difficult with complex rules combining many different types of triggers (time, timespans, devices, weather, custom events etc)...
With getSourceTrigger you could get the specific event that caused the scene to be triggered. And as I understand there is no fibaro:getSourceTrigger anymore.
Yes, but no clearTimout() that turns out to be quite useful. Then I’m missing os.time() to calculate time intervals so we don’t start to drift when doing setTimeout loops... but maybe that will come.
Maybe time to open a separate HC3 section in the forum?
So in your last example. If I want to know in the Lua action section if it was Id 25, 26, or 27 that finally made the rule trigger - how do I know that? Do I have to check all the devices again? You should be able to save away the event that made the rule true and have a function that could retrieve the event - like fibaro:getSourceTrigger() used to do.
@A.Socha out of curiosity … just reading readme.md from CPKG285-29  ?, i assume the lua engine is the same as on HC3?
Edited by tinman
Not very pretty...
Some volunteer to code os.date() ? :-)
the question is for what os.time is being used, to get some delay to sunset?
to run something every minute?
to run at specific time?
once true you can emit custom Event ( fibaro.emitCustomEvent) to your (previously)time-based scenes, where you evaluate the Event as trigger condition (e.g. as sum of counted events).
@jgab that's what I took after reading your pice of code, 20 one shot ?
Edited by Tony270570
Isn't that as "unpretty" - counting sum of events to keep track of time? (if I understod your last remark correctly)
If I want to trigger at 06:00 or sunrise, whatever comes first, how do I express that in a condition? Maybe they support more complex expressions over time? But why invent a "conditions-language" that becomes complex and idiosyncratic - when we have Lua?
The problem with the other examples are that I can get triggered at intervals but I can't tell in the action when that interval/time was.
Second example - what minute was I triggered?
Third example - what day was I triggered?
Ugly solution is to start to split into several scenes to have simple triggers so you know when/what triggered...
...another minor issue is that cron only have minute resolution...
My simple question is why? why not just add os.time,os.date,os.difftime and the other functions we had in scenes in the HC2? Instead it destroys backward compatibility for scenes like Sankotronic's Main scene FTBE with 1700 downloads, and he will be forced to jump through hoops re-implement it and the users of the scene that (finally) have something that works for them needs to start all over over. But obviously someone at fibaro thought it was worth it...
Now people will start to misuse VDs instead. "Where should I put the code for my scheduler? Well, I make it a binary sensor..." ?
Well, the code was (half) a joke - point was that I think that they should put back the missing functions or people will start to write terrible code to try to get around the new limitations imposed.
