Announcing door contact status on Google Speaker?
Hi everyone
So today I went to my friends house and he has Samsung SmartThings Hub  plus Alexa Echo Dot. He also has door contacts.
So whenever he opens the front or side entrance door, Alexa announces through Echo Dot speaker which door was open.
I want to achieve same thing with my Fibaro, Google Home Speaker and Fibaro door contacts. Is it possible ? if Yes then can you please guide me?
If no, what is alternative way to achieve this?
Edited by Janpreet
Fixing the title
As far as I know this is not easily possible with Google home.to let it speak without first being spoken to.
I do it with Sonos
that's right, one have to ask the door Status, however one can use e.g. Sonos (trigger TTS as soon door has been opened) to ask Google Home the Status which one was opened :)  Imagine funny TTS asking "hmm .. someone is out there .. ok Google, Are any doors or windows open at home?"
Edited by tinman
You could get it to work using the Alexa skill I have created. All you would need to do is get the contact sensor run a scene whenever the door opens or closes. The scene would make a http call to my website. You would create a doorbell (trigger) which would run an Alexa routine which makes an announcement of your choice.
have a look at my website
hopes this helps you
Edited by ianakapilotlight
@ianakapilotlight two questions:
  1. Is it works with alexa app on phone?  I mean can I send doorbell to my mobile?
  2. Is this solution could be used for TTS messages to Alexa also?
Edited by cag014
1. no. Not through the Alexa app. You could however do a push notification using the fibaro app.
2. Yes. Alexa routines can be created to make custom announcements. These routines can be triggered using a doorbell trigger. Given its name does not mean a chime sound is needed. Although you can if you want.
  • 1 year later...
Yes, you can do this using a node-red bridge. I made a video to announce via Google Home if someone rings the bell. You can instead use it for door contacts too.
