MichalR 0
Hi all!
I'm trying to make my heating system a smart one and need your advice.
Currently I have 5 rooms with single radiators and a wireless SaunierDuval thermostat which is programmed to steer the Saunier Duval boiler.
What I would like to have is 5 radiators with 5 Fibaro smart heads + 5 temperature sensors (5 FGT 001 + 5 FGBRS) that would be managed by a Netatmo thermostat that would steer my Saunier Duval via Netatmo relay.
Since both, Fibaro heads and Netatmo thermostat are "z-wave" compatible, they should work together, but I would like to be sure before I make the purchase.
So, could someone confirm whether my proposed setup would work?
Thanks in advance!
