Can I use the Neutral wire of nearby outlet to setup Fibaro single switch?
So I’ve bought a Fibaro single switch HomeKit but there’s no Neutral wire in my switch box although my apartment is built recently. It’s probably a stupid question but I was wondering can I use the Neutral wire of nearby power outlet for that?
Hi @Ehsan,
Yes you could if the neutral wire is switched with the same circuit breaker as you're live wire  in the switch box.
The question should also be, Is it allowed in you're country.
Ask a certified electrician if it is allowed. This to avoid any problems in the future.
 Definitely get an electrician to verify.
In some situations the neutrals from the lighting circuit is kept separate from the neutral s in the socket circuit and using one for the other can be dangerous.
Never take chances..
Edited by AutoFrank
    Thanks for the answers. While I’m trying to find an electrician, is there any other alternative with HomeKit support that could work without the neutral wire?
    Fibaro Dimmer can work without neutral, but I think there is no HK version of it :/
    In my appartment there's also no neutral wires behind the switches. They are in the ceiling fixture boxes.
    Luckily I had the space in my lamps, so that's where I installed the fibaro switches.
    But do you also have a live wire in the ceiling? I only have the switched live wire in the ceiling, so if I install it there then I believe the physical switch will turn the smart switch off as well. I mean, that way if I turn off the physical switch I can’t turn it back on through HomeKit anymore
    In my ceiling boxes are neutral, live, earth and switched live wires.
    Only the earth, neutral and switch wires were pushed through the lamp mounting plate. The live wire was easy to add and push through with the others.
    The lamps can be turned on and or off with either wallswitch or fibaro. The wallswitch activates the fibaroswitch wich turns on the lamp.
    I always installs fibaro relays in ceiling behind light, all needed  cables are always there!
