command execution time
Hi everybody!
I would like to ask help that what is the problame in my system.
I have a HCL, 10db relay switch, 6db motion sensor. The motion sensors are installed in 3 separate toilets, when the motion sensor breached then the light will turn on after 3-4 seconds. The devices are installed within 8-15 meters of each other.
I did  the "Mesh network reconfiguration" again, but there is no change in operation.
Help me please!
Thanks.
Do you use scenes or direct association PIR - switch?
What type of PIR you use, if they have parameters to set numbers of movements (action) for send info to HCL ?
    Hi drboss@,
    Yes, I use scenes to turn on the switch.
    type of PIR: Fibaro motion sensor FGMS-001 ZW5
    Form manual:
     3. Motion detection - pulse counter
    This parameter determines the number of moves required for the PIR sensor to report motion. The higher the value, the less sensitive the PIR sensor is.
    It is not recommended to modify this parameter settings!
    Available settings: 0-3
    0 – 1 pulse
    1 – 2 pulses
    2 – 3 pulses
    3 – 4 pulses
    Default setting: 1 (2 pulses)
    Parameter size: 1 [byte]
    4. Motion detection - window time
    Period of time during which the number of moves set in parameter 3 must be detected in order for the PIR sensor to report motion. The higher the value, the more sensitive the PIR sensor is.
    It is not recommended to modify this parameter setting!
    0 – 4 seconds
    1 – 8 seconds
    2 – 12 seconds
    3 – 16 seconds
    Default setting: 2 (12 seconds)
    Do the test for example with 3 = 1 or 3 = 0, parameter 4 use for calibrate situation if any person stay in room to not switch off light
