Sound Siren when Arm Alarm
Hi All,
I would like to make the siren sound when I arm the alarm.
That is, 1 second of sound, 2 seconds of pause and 1 second of sound.
How can I do?
Thank you
4 answers to this question
Hi @MarcoTorino71,
maybe you want to share your solution. It's always inspiring :-D
Enjoy coding :-D
    of course. Thanks to @Sankotronic for the code:
    - Solution 1:
    function soundSiren(n,d)
      if n==nil or n==0 then n=2 end
      if d==nil or d<1000 then d=1000 end
      for i=1,n do
       fibaro:call(sirenID,"turnOn") fibaro:sleep(d)
       fibaro:call(sirenID,"turnOff") fibaro:sleep(d)
    Use this if you have only one siren. Launch the function as:
    soundSiren(x,y)
    where:
    x= how many time the siren ring
    y= second of sleep
    change sirenID with ID of device.
    - Solution 2:
    function soundSiren(id,n,s,p)
      if n==nil or n==0 then n=1 end
      if s==nil or s<500 then d=500 end
      if p==nil or p<1000 then d=1000 end
      if id~=nil then
        if type(id)~=table then
          for i=1,n do
            fibaro:call(id,"turnOn") fibaro:sleep(s)
            fibaro:call(id,"turnOff") fibaro:sleep(p)
        else
          for i=1,n do
            for d=1,#id do fibaro:call(id[d],"turnOn") end fibaro:sleep(s)
            for d=1,#id do fibaro:call(id[d],"turnOff") end fibaro:sleep(p)
      else fibaro:debug("Siren ID not provided, nothing to do") end
    With more siren.
    Launch:
    soundSiren({id1,id2}, n, s, p)
    {id1,id2} - this is table of siren ID's that you want to sound. For one siren you can still send as soundSiren(sirenID, n, s, p)
    n - number how many times siren will sound
    s - duration of sound from 500ms to as much as you like
    p - duration of pause between sounding from 1000ms (1s) up to desired pause.
    Ciao Marco,
    hello everyone,
    i have also an issue with my siren.  It doesn´t turn off, when entering the pin on the alarm panel.
    I basicaly run/start the siren via the Advanced Alarm panel - as "Light"  (see screenShot)
    It does start when the alarm is triggered, fine.  But it doesn´t stop.
    Any tips?
    The main reason I have discovered this issue in my system is because I was about to create a "Leaving the house" - Scene and i wanted the siren to peep for a second when one of the windows sensors showing an open window.
    I know this should have been posted under a different topic ...but as there is a connection...maybe someone can help me out.
    Thank you.
    Markus
    /monthly_2020_07/grafik.png.85b2c03459eae4d2cea1f99e9b8132d5.png" />
