I'd appreciate if someone, please, provide JSON processing guideline.
I have a thermostat device with JSON API.
I manage to get the response:
but after local data = json.decode(response); I am failing to access the elements.
My initial goal is to put the data to VD labels.
The second task will be to create a JSON object and send it back to the thermostat.
Is there a tutorial for JSON handling in FIBARO?
Any help appreciated.
Thanks!
Edited by PiotrP
what say debug? and please attach your code
    Well, to have a reasonable code I need to have a knowledge first. I stuck after
    debug:
    /monthly_2020_01/image.png.260275baf73ca14c552518eec4abef7b.png" />
    How does json.decode work? How can I access the table elements resulting from decode? assign them to global variable? assign them to a button label?
    thx.
    --EDIT:
    I do not know everything but after trillion tries I figured out that simple [table_name].[element_name] is enough to access the value after json.decode. So in my case the following references produce the values I need.
    fibaro:debug (data.measurTemp);
    fibaro:debug (data.mainTemp);
    fibaro:debug (data.activeProg);
    fibaro:debug (data.progTemp);
    fibaro:debug (data.relayStatus);
    Edited by PiotrP
    the syntax for retrieve value is (as you discovered)
    23.62
    997
    33
    Edited by drboss
