duayfabi 0
I just bought a Fibaro Dimmer 2 to drive a LED driver (this one :
).I use the Dimmer 2 with three momentary switches. I can turn on, turn off and dim as the doc. say but the minimum and maximum brightness level of the led driver are not reached.
The autocalibration give me a value of 7 for the minimum brightness level and 46 for the maximum.
I tried to set 1 for the minimum and 99 for the maximum but when I do so, the effect is inverse. When I try to dim, the max level is reached very shortly (~1 second).
I finally set the minimum to 1 and leave the maximum to 46. I can dim normally but the minimum is too bright.
I think the minimun I can reach with the Dimmer 2 is in reality 10% of brightness (when the minimal brightness configured in the Dimmer 2 is set to 1).
What et how configure on the Dimmer2 to go lower in brightness ?
Thanks in advance.
Fabien Duay
