I am not sure if I'm right here. I just have a short simple question: does the new Home Center 3 also
have a connector to an external antenna - like the HC2 has? I am just asking because I place my home
controller inside a server enclosure made of iron which reduces the transmission performance of z-wave.
For the HC2 I use therefore an external antenna which works perfectly.
with kind regards
Tobias Schilgen
No, it doesn't have connector to an external antenna  (antena is on PCB)
15 hours ago, JCM said:
Tobias Schilgen
Tobias,
- the antenna being used in HC3 is much better as the monopol antenna on HC2
 (which, when mounted within iron rack, degradated transmision due to ground plane change)
- the HC3 does use RF LNA, the measured power is on the antenna, not on the modul, and it is much higher
- zw500 behaves anyway better as zw300
- iron rack does not means "no transmision possible", of course some degradation will be there,
  but at the end of the day might be still better communication as with HC2+external antenna.
I would just give it a try
