PiotrP 0
I tried this.
it works with GET end empty payload. But when I switch GET with PUT and fill the payload I receive:
/monthly_2020_02/image.png.dcf2d727ccea9ffd4f91da380069b938.png" />the IP address is 192.168.1.101/write
What is the correct way to use PUT method?
Thanks!
--EDIT SOLUTION--
IThe correct format for sending PUT request is:
selfId = fibaro:getSelfId()
deviceIp = fibaro:get(selfId, "IPAddress") -- VD ip address
devicePort = fibaro:get(selfId, "TCPPort") -- VD port for ip
TERMI = Net.FHttp(deviceIp, devicePort) -- object definition
payload = '{"INTERVAL":"true","iTemp":"'..iTemp..'","iDuration":"'..iDuration..'"}' -- whatever payload you need, in my case some JSON objects
response ,status, errorCode = TERMI:PUT('/write' , payload) -- remember to include payload!
Best regards!
Edited by PiotrP4 answers to this question
