lua command 30 minutes before sunrise and after sunset
I have a goog working Lua script for  Dag (Day) and nacht (night) variable.
The settings are for the variable Day and night are exactly start at sunrise or sunset.
But now i want to program 30 minuts. So the variable Dag (Day)  for sunrise must start 30 minutes later  and for Sunset 30 minuts earlyer.
Dous anyone now where and how i must programm a 30 minutes code?
This is my Lua code:
%% autostart
%% properties
%% globals
--Deze senne maakt van variable Nacht.
--Wat heeft de scene gestart?
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
   --Controleer elke minuut het tijdstip
   while true do
   --Defineer de tijden
   local TimeNow = (string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min))
   local sunrise=fibaro:getValue(1, "sunriseHour")
   local sunset=fibaro:getValue(1, "sunsetHour")
   fibaro:debug("Het is nu: "..TimeNow)
   fibaro:debug("Zonsopkomst: "..sunrise)
   fibaro:debug("Zonsondergang: "..sunset)
   --Bij zonsopkomst
  if (TimeNow == sunrise) then
      fibaro:setGlobal("Dag_Nacht","Dag")
   --bij zonsondergang
   if (TimeNow == sunset) then
       fibaro:setGlobal("Dag_Nacht","Nacht")
   --wacht 1 minuten
   fibaro:sleep(60*1000);
else
   --dit gebeurt als je handmatig scene start
   local Dag_Nacht=fibaro:getGlobalValue("Dag_Nacht")
   if Dag_Nacht == "Nacht" then
   else
9 answers to this question
    My scene is also running in the backround, and is working perfect for exact givinging the sunrise and sunset moment for my Day_Night variable.
    Also my script looks less complex as yours with all respect of course.
    So i only need the rigth code extra for 30 minutes (or what ever) to give the sunrice and sunset moment a delay of earlyer.
    Edited by rjansen
    The point is that you don't need to deal with the Timer scene - it runs in the background, your own scene just declares the hours it want to be triggered - and you can easily add variations for days, weekends months etc.
    It keeps the scene clean, doesn't need to loop every  minute 24x7 to check times  and I think it's easier to understand - but that's a matter of taste.
    Btw, your scene is not working perfect - it can fail the tests "TimeNow == sunrise" or "TimeNow == sunset". The reason is that your scene drifts as the loop takes a little longer (a few milliseconds) than 60*1000 milliseconds. This will result that once in a while it will skip a minute and if that skipped minute coincides with the sunrise/sunset times it will miss it. Murphy's law states that it will happen that day when you really really rely on the variable being updated...
    In general it's not advised to do exact time comparison like 'now == time'. Alternatively fix the loop so it doesn't drift.
    You can also fix your scene by adding:
    ...and test your sunrise/sunset against TimeNowPlus30 and TimeNowMinus30...
    and avoid Murphy by changing your 'while true' loop to
    Hi Jgab,
    A oke, i understeand what you are meaning.
    I will try your scene for look and feel.
    Thnx for so far
    by the way. It dousnt matter to me that one time the 1 minut trigger miss the sunset/sunrise time. It will activatet a minut later.
    I use this scene in to anoter scene wat use de Day / Night value of burning a bulb in the house with the motion trigger. When its Day, it will do nothing and when its Night, the Bulp will burning when trigered by the motion sensor.
    Edited by rjansen
    It will miss a sunrise or a sunset  for the whole day... not just a minute.
    If the sunset is at ex. 21:30, your checks, if you are unlucky, will test 21:29, 21:31 - i.e. skip the 20:30th minute.
    Hi Jgab,
    I don't know what you meaning.
    The scene checks every minute if it is sunset or sunrice.  This not a fixed time, but will automaticly changes each day the sunset and sunrise are later/earlyer. All the time it see its sunrise, its getting the variable "Dag" (day) and  my other scene wat must trigger te bulb knows, when its still day, it don't activate the bulb when te motion sensor is breached. Fot the value "nacht"(Night) it will al the night  activate the Bulb when the morion sensor is breached. So the combination of those scenes' are working realy fine with eachother. Ony i want that the motion sensor can be activate  the buld arround 30 minuts later of earlyer then the exact time of sunrise and sunset.
    Ok,
    your loop that waits 1minute
    Ok,
    You have a loop
    The problem is that the "Inside" of your loop takes a little time to execute, let's say 1ms.
    That means that one loop doesn't take 1min, it takes 1min and 1ms. That means that if you started the loop exactly 22:00:00, after 1000 minutes you have drifted 1000*1ms = 1s. and it is 22:00:01
    That may not seem so dangerous?
    Well, assume that you started the loop at 21:59:59:999 (21:59:59 + 999ms) - and assume that sunset is at "22:00"
    First turn in the loop you test "21:59" == "22:00", which is false (current time 21:59:59:999 is truncated to "21:59")
    Your loop takes 1ms, so we add that to the current time, which becomes (21:59:59:999 + 00:00:00:001) = 22:00:00:000
    Then you sleep 60*1000ms and the time becomes 22:01:00:000
    Next turn in the loop you test "22:01" == "22:00", which is also false
    --- You skipped a minute. And you will not get another match until next day.
    The problem is that this happens rarely, but it may bite you when you least expect it and you will be convinced that it is Fibaro's and the HC2's fault, because the scene has always worked in the past....
    As we often saw here on forum in the past ?
    Beside Scene Timer you can try All-in-One Scene as well
