trigger by variable change [SOLVED]
Hi there,
I try to have a scene turn the lights on and off with a variable. I can't figure out why it won't trigger.
I have a predefined variable with the value 'Aan' and 'Uit'
LUA code:
Solution:
To complete my question: I have a MQTT -> Node-Red function to send a PUT request to Fibaro HC. I add 'invokeScenes': true in my request that triggers the scene to run.
Node-Red function:
Edited by boogie1982
Found a possible solution
