Scenes on the scenes
I have a problem, I like to make the scene in fibaro HC2 where to turn some scenes to manual mode
How this is possible
@Jaanus45 can you describe what you want more detail?
Hi. You can do it via LUA. Here is description of the function you need from LUA API doc:
fibaro:setSceneRunConfig(sceneID,runConfig)
Function name must be always the same:
Application
Where runConfig is string that takes one of these three values:
TRIGGER_AND_MANUAL
MANUAL_ONLY
DISABLED
 Which will set given scene respectively to Automatic, Manual and Disabled mode. Any other value will set scene triggering mode to Automatic.
