FGS-213 long press to start scene
How can I make a long press or double click launch a LUA scena?
6 answers to this question
First of all you need to enable scene activation according to your needs. Configure device parameters 28,29
Then create a scene like: (please change <devID> to your switch real ID number)
trigger.keyAttribute  available values are:
Key Pressed 1 time
Key Pressed 2 times
Key Pressed 3 times
Key Held Down
Key Released
Edited by cag014
    Thanks, I´m still struggling a bit though.
    Parameter 28 & 29, all options are ticked in.
    DevID, is it the master or any of the slaves? My master ID = 20 so thats what I´m trying below.
    This is the code I´ve got, it´s a single switch so i guess only the S1-part matters, but I copied it anyway.
    The debug gives me som kind of error connected to this scene (171), I guess something is wrong with line 8? (see attached picture)
    /monthly_2020_02/image.png.96e4df48b8f0f8df7be72af0021c6013.png" />
    I hope you don't run it manually , it won't work... it works only when triggered by device
    Please add this line
    fibaro:debug(json.encode(fibaro:getSourceTrigger()))
    before
     local trigger = .....
    Let's see what trigger data is?
    Edited by cag014
    By the way I think the key attribute for fibaro switch is slightly different and might be in your case attributes are
    Pressed
    Pressed2
    Pressed3
    HeldDown
    Released
    If so please change "Key Held Down" to HeldDown"
    Edited by cag014
    Thanks!
    That and changing devID to the first of my slaves (21) instead off master (20) did the trick!
    Sorry, didn't spot that you mention this is master... it should be slave.
    Well done.
