baskalex 17
I have a Danalock which is situated on the edge of HC2 range and it receives commands maybe one time out of 10. But it stubbornly doesn’t want to do any hops via intermediary devices which there are plenty of between the lock and controller. Fibaro door-window sensor located on the same door for example easily hops via two devices and works reliably.
so the question is if it’s possible to manually set its routing to make hops? Probably with UZB?
24 answers to this question
