Hi guys need some advice,
Since beginning of December I have some problems short period (seconds I think)  lost of connection.
First setting was on modem provider 3 TV's and a cable to my Asus Router.
My network consist off:
provider modem
router Asus
switch
This set up is recently done on advice off the provider because of problems!
The provider modem;
-contains only one cable out >>>>Asus router
-wifi>>>off
Asus router:
3 TV's
switch>>>
HC2
Hue
Pi
Home Cinema
Media player
wifi
Hi-home smart plug
Harmony
IPhone
Home Connect
Hi-Home sends me a message connection lost
Alexa will answer I have a problem connecting internet .....
My Harmony Hub shows red light and needs to be reconnected
There is no problem with HC2
How to approach this problem is it the Asus or the provider?
Thanks in advance,
//Sjakie
reading router logs (if feature exists) can help you.
otherwise you with black eyes.
on;y router (connected to ypur ISP) can says what happened - is that own router issues or your ISP is not stable.
Is you're provider modem a modem/router or a "bridge"
Had a simular problem,
The connection was provider modem/router and a fritzbox modem router.
So I requested my provider to set my modem into bridge mode. The fritzbox function as modem router now. because i ddn't like the possibiltys of the provider modem.
Edited by Flash
    Its in bridge mode
    ...and provider now can see ALL your devices in network. Bravo ?
    How?
    Al ports are blocked. No exrnal acces possible. Strong password protected.
    But the Asus log could provide some inforamtion. And contact the provider if the modem stil in bridge.
    Edited by Flash
    Hi @10der
    ok so if in "bridge" all local IP adresses are visuable for them?
    I dont understand
    My ASUS is giving ip adresses in the 198. range
    how the can see what my router is doing?
    So I should go back to the previous set up but according the guy it will conflict their modem and my router
    Please explain
    //Sjakie
    I feel myself a bit trunked.
    In the previous setting I could check with wifi on the modem of the provider.
    Now its more difficult for me to discus this with the provider.
    They have monitored the connection and say nothing is wrong with it.
    Yesterday a dip or lost connection and according them there was no breakdown or more notifications on that specific time.
    Its frustrating several months sometimes slow internet 35-75Mbs. Speed is okay now 95-105 Mbs.
    //Sjakie
    Please explain, beacuase i don't understand you post?
    My modem/router is also in bridge mode en my router behind that is a edgerouter 8 pro and i don't think someone can see my lan devices.
    //Sjakie
    it depends, sometime you can see in you're modem what the uptime is.
    does the connection drop only happens to wifi devices or also with devices with a cable connection?
    i guess you have xdsl, wich provider?
    Edited by akatar
    Cable from Delta
    In the Asus Isaw the log but the incident was much earlier so nothing to see.
    Both Harmony and Alexa are WiFi
    Sometimes my TV modem is stucked too he is cabled that I thought to solve to switch it off every nigt but that did not helped
    //Sjakie
    mmh Strange my laptop sees the Modem WiFi provider (should be switched off)
    My IPone doest see this!
    perhaps you're provider modem is not in bridgemode? then you will have problems because "nat behind nat"
    • 3 months later...
    So I asked my company to set my modem into bridge mode. The fritzbox characteristic as modem router now
    . Due to the fact i ddn't just like the possibiltys of the provider modem.
