airglider 0
Bought a Smart Implant a few weeks back with the idea to use IN as analog input to monitor voltage on a LED (Home Alarm).
- When alarm is armed (green LED) voltage is 5.1V.
- When un-armed voltage is 3.3V.
My idea:
- Configure IN1 as analog input (parameter 20 set to 4 or 5, whichever works).
- Configure parameter 63 "Analog input - minimal change to report" to report on 15 (changes of 1.5V).
- I expected Out1 to shift between Open & Closed.
However, IN1 will not shift Out1 from Open to Close when connected to the LED.
At the moment I have a solution that works - have connected a switch grounding IN2 (op mode "Bistabel"), and by this having Out2 shifting between Open and Close.
My question - is it possible to monitor a voltage level and have Out shift state? If so, how to configure?
Thanks!
Brgds /Thomas
