LBB 0
Hi all,
I'm a newbie at this and stuck on something which should probably be simple. I have created a Global Variable "HomeAway" with three values (home), (Away) and (Workweek).
I have then created a virtual device so that i can make a button to set this variable. Once done I will use this to manage a range of things in the house like hot water, heating, blinds and lighting. But I just cant get the virtual device to change the variable. I have found plenty about this online but all solutions i read don't work.
It seems i need to add code into the virtual device. but what code. The LUA manual says this line should work "fibaro:setGlobal(‘HomeAway’, ‘Home’);" but nothing happens.
Any help greatly appreciated.
/monthly_2020_02/image.png.7f4ca6814b2d0a3cbdb7a2f4a95ec384.png" />5 answers to this question
