I have a single switch with a fibaro dimmer 2 that controls two lamps. I would like to change this such that I can control both lamps seperatly.
My plan is to change to single switch to a double switch (and connect them as described in the manual). I intent to add a second Fibaro Dimmer 2 in the second lamp.
My plan is to configure the system such that one of the switches (s1) in the double switch controls the dimmer 2 that is connected to it (and switches / dims the lamp connected to it), and that the second switch (s2) is just read by the fibaro. This signal is sent to the 2nd fibaro to switch / dim the 2nd lamp.
RHAS 0
Is there a way to do this?
Thanks for your help.
René
Link to post
