Mobile device location not working
I am trying to get the location of my mobile phone inside LUA scene.
- I have turn on for fibaro app on mobile phone to get location always (not only while using the app)
- I have set up in configuration to retrieve location for device every 1 minute (most frequent)
- My lua code:
local location
local location2
location = fibaro:get([mobileDeviceId], 'Location')
location2 = fibaro:getValue([mobileDeviceId], 'Location')
location and location2 are always nil when I run the scene manualy (start button)...
I have right mobileDeviceId ( I have create a block scene for push notification which I recieve and than convert the scene to LUA to find the deviceId - so I have correct Id...)
I am not sure  if I should retrieve the location with fibaro:getSourceTrigger() function and than check the GeofenceEvent 221 but in this case I think I can only get true/false if device is in certain range that I defined and not the latitude / longitude  that I want to have to calculate the distance etc...
Is this even posible with fibaro to get the exact location from mobile device in lua code?
Thank you for your help
