HC3 in iPad App
It is not possible for me to get the HC3 in the iPad app, have you the same problem or can you help me??
Greetings Poldy2000
5 minutes ago, VedranS said:
With hc3 , i cant even turn my lights on. Ripoff
Then you are doing something wrong
HC3 works just great with me. Except for that system needs more improves.
only a opinion, the last app is horrible, I still use the old app....
can anyone tell me if is worth to change from hc2 to hc3?
Edited by LMPS1979
The HC2 was much better imo. They seem to have gone backwards with the HC3 and to make it worse, the back catalogue of scenes etc that has been built up over the years now no longer works with the HC3.
I would wait. The old app will not work with the HC3 and this has caused me a lot of problems. I have been told the new app will be receiving some updates to work with tablets correctly though, so this will hopefully help a little bit, though it is still to be seen if it will be even as good as the old app.
The mobile version did just get an update which has made things slightly better but things seem to move very slowly over at Fibaro! Whoever they have working on the app, he needs a rocket putting up his ass :)
Edited by couillerot
I can highly recommend getting a Homebridge running, which allow you to control your Home Center through Homekit.
I think Homekit is the best UI and easiest way to control things and it also gives you full Siri Control :)
(and you no longer need to wait for Fibaro to update their crappy app)
It's worth mentioning it's a very simple installation and the software is easy to configure. Personally I run this on a NUC, but I think it can also work well on a Raspberry Pi.
On 2/26/2020 at 4:25 PM, Patricier said:
The new Iphone app does not show any of my Philips HUE lights, neither from my HC2 or from my HC3.
My Hue lights didn’t shown up until I added a new bulb. And from that time they showed up in the Fibaro App.
Maybe you can try to remove and add a bulb.
On 7/3/2020 at 8:58 AM, jakub.jezek said:
FIbaro works on landscape mode for Home Center app. I cannot tell (do not have the info) when it comes, but it will come.
7 months later ... ?
So you are not counting beta app?
Below is screenshot from my Android emulator.
Nice for you … but I don’t have a beta. Secondly … 7 months for a “new” app is just to long.
Edited by Sjekke
Why not install the beta App. I am not a fan of beta firmware, but I do like the beta App (in comparison with the previous version).
You now, it is open beta right? You can install it and try it for yourself. Link
I agree, but this time period gave much needed feedback for both HC3 and Home Center app, so they could focus on bug fixing in both and bring new features.
I didn’t know there was an open beta. Thx ?
Installed ?
Edited by Sjekke
Updated to the latest version and my icons disappeared… anyone?
I have read somewhere, first to use the app on local network, then icons work on remote network (?)
I got the latest beta pushed this night. I think you talk about version 1.10.0.17?
The icons disapeared here also, please report a bug via TestFlight (on iOS).
I run 1.11.0.3 on iOS.
Icons are available. Maybe first use on local netwerk and later on remote network?
It looks like you got a newer version pushed.
/monthly_2021_03/image.png.a3086b4e665f11532eaa40b42b97f106.png" />
As I expected. They fixed the bug. In my Testflight I have version 1.10.0.17. The new will arrive soon I think.
