I have some Nexa ZV-9101 (z-wave plus) downlight dimmer actuators.
They are mounted between a manual wall switch and the downlights, so I can use wall switch or HC2 app to turn lights on/off.
Earlier HC2 showed the light state correctly, but now something is wrong.
When swithing light on/off using HC2 mobile app, everything goes OK.
But where using the wall switch manually, the HC2 does not recognize the new state for the light.
I have to poll the device to get the correct state in HC2.
I am using Fibaro HC2 software version 4.580.
Hope that someone can help me.
Best Regards
Eirik Flaten
Edited by EirikFlaten
Uncheck, confirm and recheck and confirm association in advanced tab of dimmer, maybe this help. In some case after upgrade the hc2 loss association for lifeline group.
BTW, Fibaro changed something in 4.571 beta and 4.580 because I have the problem with information about state of qubino products, witch work without problems before.
    Thanks for answer. I tried to do this - not working properly, but there are some changes.
    Now HC2 recognize that the manual switch has turned the lights ON.
    But when turning OFF, the HC2 state of the light is ON at 69% strength.
    When pushing the "Pull button" in HC2 advanced mode, the state is corrected.
