barend121 13
after a power outage I found the HC2 with all lights on flashing and not functioning.
I plugged out the power adapter (on the adapter side) and reinserted it, the HC2 came alive, after a few lights on (moving from right to left) all lights went off.
I re-tried this procedure (pulling out power and reconnected it) and same result, lights came on, and after a few seconds, all lights went out.
I unscrewed the left panel to assure the HC2 power plug was well connected into the device, and the device came alive and everything worked as expected.
Does this ring a bell? Is the power adapter defect? is the HC2 defect? Is there something else wrong? hope someone got a clue of has an answer, the Homecenter is quite important and preventing a failure is better than experiencing one :-)
Thanks for your help!
can this has something to do with it? I also pressed the buttons on the back
