Version 4.581 Beta
The possibility of transferring the cloud backup to Home Center 3!
- Use the Transfer Configuration feature available from the Remote Access (home.fibaro.com).
- Both gateways must be assigned to the same Fibaro ID account and available on the Home Center list.
- The backup must be created on version 4.581 or higher.
- Home Center 3 must be on version 5.021 or higher.
- All Z-Wave devices, their configuration, room assignment, associations and parameters will be transferred.
- If you have thermostats, they will await reconfiguration.
- Scenes will not be moved and need to be created again.
- Virtual devices will not be moved. Use a new tool - Quick Apps - to implement them.
- The gateway from which you are moving the backup will still be available, but the devices will no longer communicate at all.
- The migration process cannot be undone - it is irreversible.
Migrating data from Home Center 2/Lite:
