problem with connected
xronical
I bought double switch and I wanted engage it. but I have one problem. I attached picture with scheme
when I engaged this (Picture with fibaro module) so, fibaro module it´s ok (via phone or pc), but wall switches not works.
But when I used multimeter and I linked S1 with N (picture) all switches working fine. Can you help me please?
4 answers to this question
Hi @xronical
I asume that if you use the switch the multi meter also gives 230 Volts, on S1 and N?
Have a look at the parameter 20 settings.
here you can decide between the diiferant kind of switches and state.
  • hi
    yes multimeter gives,
    I tried change parameters 20 but, is very strange, because when I push wall switch (middle where is fibaro) about 6-7 times very fast, so  lights on, but only from this switch
    Try to use S2 and Q2 and see if you have the same problem. Because this is very strange.
  • I tried it, but result was the same....
    I think that module is good, because I tried with another wall switch and work fine
    So I dont know where is problem
