Sceny
Witam,
Jestem laikiem  w tej kwestii dopiero zaczynam się bawić Fibaro,
ktoś może mi pomoc jak zrobić scenę
w łazience gniazdko ze single switch - podłączony grzejnik elektryczny
chciałbym żeby  scena działała od godziny 5 rano do 23
i w tych godzinach grzejnik włączał się gdy temp spadnie poniżej 21 C a wyłączał się gdy bedzie powyżej 23 C
oczywiście jest tez zamontowany sensor Fibaro
z góry dziękuje za pomoc
Please try to use
. No Lua knowledge required.
Let me know if yes and I'll post solution for that.
    Yes please
    On 2/27/2020 at 5:28 PM, Romyy said:
    I'm a layman in this matter, I'm just starting to play with Fibaro,
    someone can help me how to make a scene
    in the bathroom a socket with single switch - connected electric heater
    I would like the stage to work from 5am to 11pm
    and during these hours the heater turned on when the temperature drops below 21 C and turned off when it is above 23 C
    of course there is also a Fibaro sensor mounted
    thank you in advance for your help
    OK, since I don't have device IDs I'll use demo number.
    After downloading All-in-One Scene
    Please set as below (change numbers 300 and 400 to your real device ID.)
    add to jM  two lines (last 3 lines are part of downloaded code.)
    Save scene and it should start.
    Edited by cag014
