pirotadam 0
I have got 1 Walli Dimmer (FGWDEU-111 firmware v5.1) with 3-wire connection and a Home Center 3 (v5.020.60).
This Walli Dimmer manage 5 IKEA Tradfri E27 806 lumen 8.9 Watt led bulbs. After mains voltage drop problem, I changed the minimum and maximum brightness level from 1 - 99% to 5 - 50 %. This resolved mains voltage drop problem.
My additional problem with this dimmer is that on my iPhone (Fibaro Home Center app v1.6) I set dimmer to 20%, after a while the brightness is go to down to zero, there is dark in the room, and the dimmers led ring is white, so the power is ON.
Can somebody say, which parameter can I modify to the 20% dimmer brigtness parameter work properly?
I dont use Fibaro Bypass2 yet!
7 answers to this question
