How to decode Json / Lua in Variable
Hello, i have a question.
how can i write result from a JSON in a Fibaro Variables
This code works but i don't Know how i can write into Variables
can anybody help many thanks
and here the resalt
[DEBUG] 17:21:36: ["80s 90s stuff","miro","SIA","Top Hits Deutschland"]
you have two command for working with json on HC2:
json.decode()
json.encode()
in your example
the result for 'b[1]' is:
80s 90s stuff
b[2] is:
miro
    Hi Thank,
    but in your post  "a" is a fix variable.. how can i  write my "Call" into "a"
    thanks
    Markus
    well i  check this but now i have another Problem..
    in the JSON file the field "integrations" sometimes not exist so the lua Code went into an ERROR... how can i handle this
    can you please help
    Edited by hoschi_66
    Hope it helps
    Enjoy coding :-)
    On 3/2/2020 at 9:46 PM, Sankotronic said:
    Hope it helps
    Enjoy coding :-)
    nice many thanks  it works !!! and it is so easy :-) sometimes in Germany we Say " man sieht den Wald vor lauter Bäume nicht !"  now i can testing with Owntracks :-)
    • 4 years later...
    Hi.
    I want to make a global variable that contains the current stock price for electricity. I get a json string. I'm converting it to a Lua table. And for some reason I get zero. What am I doing wrong?
    hub.getGlobalVariable("EnergyPrice")
    local url = "https://dashboard.elering.ee/api/nps/price/EE/current"
    net.HTTPClient():request(url, {
        options={
            method = 'GET',
            headers = {
                ["Content-Type"] = "application/json"
            timeout = 5000
        success = function(response)
            EnergyPrice = json.decode(response.data)
            hub.debug("EleringPrice", response.data, EnergyPrice.price)
        end,
        error = function(errorMessage)
            hub.debug("EleringPrice""HTTPClient error" .. errorMessage)
    Just try this one:
    On 5/1/2024 at 7:22 PM, Sankotronic said:
    Just try this one:
    Unfortunately it doesn't work
    Hi @Eldar.D. ,
    Try then:
    6 hours ago, Sankotronic said:
    Hi @Eldar.D. ,
    Try then:
    Thanks, it's working.
