Denon-AVR-X1100W and Denon-AVR-X2400H
Leszek_Fibaro
I have two Denon amplituners
The old amplituner Denon-AVR-X1100W works with the Denon plugin from Fibaro. The old amplituner had active GUI available via http
The new amplituner Denon-AVR-X2400H do not have a GUI available via http
and do not work with plugin Fibaro.
I found a solution how to make a virtual device for Denon-AVR-X2400H
1. Amplituner must be connected to a home wifi network. My Denon have http://192.168.188.25. My router is Fritz!box - I see my Denon like that:
2. Create new virtual device
Insert  your address  (for example - my address "192.168.188.25") and port "8080"  (always 8080)
Add two buttons
Insert:
GET /goform/formiPhoneAppDirect.xml?MVUP HTTP/1.10x0d0x0a0x0d0x0a
GET /goform/formiPhoneAppDirect.xml?MVDOWN HTTP/1.10x0d0x0a0x0d0x0a
Remember it
/monthly_2020_03/obraz.png.bacdaf78f382faa4e2f0ef743b247a38.png" />
Ready - you can now control the volume!!! :))
Finally, you can change the icon  (see Urządzenie Denon AVR.png)
You can find other Denon control commands "http" in the internet
for example
REMEMBER:
and this command work in Firefoks, Opera, Chrome....
In plugin Fibaro you insert in botton virtual device:
GET /goform/formiPhoneAppPower.xml?1+PowerOn HTTP/1.10x0d0x0a0x0d0x0a
GET /goform/formiPhoneAppPower.xml?1+PowerStandby HTTP/1.10x0d0x0a0x0d0x0a
Good luck :)))
Edited by Leszek_Fibaro
  • Thanks 3
On 3/1/2020 at 12:16 PM, Leszek_Fibaro said:
/monthly_2020_03/image.png.a5ddb2a780957c13d6a4ecbf0416a8e3.png" />
Leszek :)
I'm currently building a VD for my Denon AVC-X4700H and found this Excel sheet with command detail that might be helpful:
