Working only manual syncronization sensors. To HCL connected smart implant. HCL is slave. If i syncronize from HC2 by hand. This time HC2 see smart implant states. Where is the fish ?
  • 4 weeks later...
hi,
Did u found out what causes the problem? I have the same issue.....
Greetings TSN
  • 1 month later...
Anyone solved this problem ? Have same, between HC2 and HC2.. connection is OK for few hours max days and then it get stuck...
