What the hell is this?
I RH_Dreambox can no longer access my forum account.
When I was to log in, I was asked to log in with my Fibaro ID. When I logged in I was asked to enter username (RH_Dreambox), but then got the answer that the username is already in use?
So now I have logged in as RH-Dreambox but all my history as RH_Dreambox is gone! ?
How do I fix this?
me too.
My old Username is
MarcoTorino71
Edited by MarcoTorino71
mee to ?
Quote
If you have a FIBARO ID account, you will now use this account to log in to FIBARO Forum. If you do not have a FIBARO ID account and you want to keep access to FIBARO Forum website, we ask that you register one. Please keep in mind that if you wish to keep your profile history (content),  the email address assigned to your FIBARO ID account needs to be the same as the one used on FIBARO Forum.
Are you sure that this account
uses the same email address as your FIBARO ID?
Note that they have to be the same in order to be merged.
Hey people our old admin @T.Konopka is with us again :-D
Just passing by ;)
Checking if everything works fine :D
I had the same issue
it looks like it was caused by using a one email address for the fibaro ID and a different one for the forum
Using the same seems to solve the issue :-)
@T.Konopka
 you can delete account autofrank2
I had it created before I figured out what the issue was ..
sorry about that :-)
23 minutes ago, K.Drozynski said:
@AutoFrank, done.
Thanks..
35 minutes ago, K.Drozynski said:
@AutoFrank, done.
Can you also merge my account (account name akatar)
thanks
but why the change on this forum??
2 minutes ago, akatar said:
The force is strong with @T.Konopka
As always ;)
@T.Konopka  I'm still having strange behaviour (Tony270570) is talking :)
Edited by Tony270570
Can @T.Konopkamerge my Accounts speedoxx007 with speedoxx007-2 ? Thanks forward.
15 minutes ago, T.Konopka said:
@TonyID27 , ok. Don't move :D
@Tony270570 , what about now
TonyID27 is gone :) Tony270570 is back ! Thank you @T.Konopka !!
@speedoxx007-2
@speedoxx007, done ;)
@RH_Dreambox , talk to me! Solved? :)
To all, note that from now on you will get notifications from the Forum to the email address linked to the FIBARO ID. So, if you used a different email address for the Forum account, it is now gone and is not used anymore.
