TheDarthFather 0
I bought the Dimmer Switch from
and a led fromPlease login or register to see this link.
.It seems I am doing something .. or more than something .... wrong:
1. Initialy i thought I have a 3-wire / neutral wire wiring, but i realised later the the third cable must be just a link done for another plug ...
Anyway during that test (where I connected the third wire as a neutral ), the led was flikering.
I tried to force calibrate from the HA .... and I used this
on the lamp.Interesting the device tried a few times to calibrate, and in one phase it was clear that he found the correct way (was dimming from min to very bright) , .... but after calibration ... blinked again rapidly ...
So .. I am lost .. how come was working (even if flickering) if i had that type of wiring ? Also ... why did he not "keep" the correct setup ?
The "smart" On-Off worked .. but of course it was flickering as well ...
2. I connected using the 2-wire diagram:
In this case when I switch on, my lights are having a very low brightness. If I press again they go full brightness for a second and they go back at a very low brightness ...
Is this a normal behaviour before calibrating ? Or I did not wire them correctly ?
I cant recalibrate now .... as my HA config file was corupted during one of my too-many unfortunated power-downs (forgot to shutdown HA before).. wich came with my next question:
How do I factory reset the switch to add it back to the HA ?
I tried clicking 3 times, long click and re-click .. but did not work ...
Thank you!
