Wouldn't it be good to create a folder under Downloads for QuickApps.
If one or the other has developed something, it could be made available for the community
Here you go:
    Thank you very much ?
    We are working on Marketplace where we soon will give option to add there quick apps
    2 hours ago, K.Drozynski said:
    Here you go:
    It is a hidden link?
    It could not be found or accessed from download section and following the link no way to add files to this "hidden" section either.
    I'm curious about how to submit files to market place?
    I mean, if there are any specific requirements to post file there? For example I thought to post Z-wave monitor there... is it acceptable?
    Edited by cag014
    @cag014 how about now?
    You chose name, platform, type, manual how to configure. Someone from Fibaro check it and then after that we publish it
    /monthly_2020_03/obraz.png.32eb4a84571ba6191246789c218724fc.png" />
    thank you
    Perfect... thank you
    If you don't mind, please add the TCP connection sample Fibaro have posted and that you kindly linked to me, into the downloadable folder. For Global Caché specifically, the QA button should contain this:
    self:send("sendir,[long IR-code]0x0D0x0A", true).
    At the end of the IR code, one must add 0x0D0x0A.
    Example of the Power Button for an Onkyo receiver:
    self:send("sendir,1:3,1,37878,1,1,340,169,22,21,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,21,22,21,22,63,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,21,22,21,22,1500,340,84,22,3631,340,84,22,37000x0D0x0A", true)
    TCP connection sample (for devices like Global Caché)
