Fibaro Roller shutter, door sensor, & Google Assistant
Hi all,
Hope all doing well
I'd like to know if we can see and manage on google home application
Fibaro roller shutter & sensor door
thank you for your support
Lahoucine
4 answers to this question
    Sorry Fibaro team,
    Why we can't discover fibaro ruller shutter and doors sensors on Google assistant?
    I m sure this is not a Google home /assistant restrictions
    Please have a look at the attached Pic.
    Need a response please
    Regards
    Lahoucine.
    Edited by Lahoucine
    Google sure has some restrictions. This is done on purpose as far as I can find out: Google will not say anything if not prompted first by user, so it wil not be used as an alarm for not nast-devices.
    Also it seems it will not support blinds etc, for this can be potentially dangerous (try to escape a fire thru a garage while the door won't open)
    Is there an update on this topic? Somehow my scenes and roller shutters are not visible on my Google hub, but that should be supported (
    Would be great to control my blinds...
    I gues its not the answer you are looking for...but just to let you see there are more solutions to achieve the Google assistant integration
    Altho mine has extra costs while the Fibaro solution is totally free.
    I am using the Fibaro rollershutter modules with Google assistant for years already, and its working great.
    The rollershutters are visible in the interface. The scenes are not. You can just say "Start %SceneName%.
    I am not using the native integration of Fibaro > Google Home, instead Iam using a Automation Bridge between Fibaro and Google Home.
    Besides that i can publish also two button (On/Off) VD's to Google assistant which is totally awesome.
