How do you write lux in home centre 3 in Lua code
12 answers to this question
As a trigger?
    I want to turn on lights when it get to dark
    Edited by Stone House
    Guest Freddan67
    It doesn't work for me either It works when I run the scene manually.
    I use lux in combination with movement. When movement and lux too low, then turn on the lights. That works fine, because there is a significant trigger of movement and you can read out the lux as a secondary condition. On lux only I don't think it can work, because then the lux measurement should be nearly realtime.
    how do you right that in Lua code ?
    thanks that helps a lot
    could you help me on this scene from hc2 to hc3 not sure what I need todo
    I would just used the block scenes. If you than prefer LUA, then it would look like:
    (for the "turnOn" part)
    when I make the curtain to open can you put it in the same Scene or do you have to make a new one?
    You open the curtains in the morning, I would use a separate (block) scene
    yeah it all working thanks I used Lua code
