Mads 0
Hi I am using Logic-groups Matrix dimmer ZDB5100 (Multi channel device) and try to make it work with the new Home center 3. I can control brightness in the matrix dimmer from Home center 3, but when you physically press the matrix dimmer unit no change appear in Home center 3. This makes me unable to use the buttons for scenes and the light level is not updated in the user interface. This is normal and this is solved in a Home Center 2 by associating the Matrix unit's lifeline status directly with Fibaro Home Center 2 and the user interface is always updated according to the status of the pressure. The problem then is in Home Center 3 that it is not possible to choose the Matrix dimmer to associate with home center 3 under association groups ??. Does anyone have a solution for this ??
