salocloete 0
Hi
I’m from South Africa. i would like to know what third party device is compatible with fibaro home centre with regards to controlling a Geyser (home water boiler)
our geysers work with a typical 3kW element with a slot for a thermostat to push into it. the thermostats are typical bimetal thermos, ant they control it by switching the element on and off.
So I would need a contact that could handle between 10 and 20 amps or i could use an external relay as well, but would near a external probe to measure the temp.
I have seen on line that Qubino do manufacture exactly what I would need, but I’m not sure if it is compatible with Fibaro, and or are there other options
Would appreciate your feedback
